#1 Oil Pressure sender 3,8
Posted: Wed Jan 21, 2026 4:52 pm
by adam
Hi has anyone tried the oil pressure sender from Classic Jaguar. They claim it is made to OE spec £144 but is it just a generic one selling for more money.
Thanks Adam
3
#2 Re: Oil Pressure sender 3,8
Posted: Thu Jan 22, 2026 12:15 pm
Don't waste your money, install a mechanical oil pressure gauge for much better accuracy. Details in the 'Upgrades' part of the Forum.
#3 Re: Oil Pressure sender 3,8
Posted: Thu Jan 22, 2026 2:08 pm
by flatfloor 3.8
As above, fit a wet gauge and be done with it. All the senders are unreliable.
#4 Re: Oil Pressure sender 3,8
Posted: Thu Jan 22, 2026 4:33 pm
by adam
Thanks I will look into that,
Adam
#5 Re: Oil Pressure sender 3,8
Posted: Thu Jan 22, 2026 10:31 pm
by lowact
It's not original. Position of the terminal is the giveaway Original had the terminal in the centre, this one has it on the side. The difference is dictated by the internals. The original with centre terminal was a Smiths bi-metalic type that was passably accurate when paired with our bi-metallic gauges; NLA. The senders with the side terminals are resistive type, substituted by Caerbont, that do not work well with original Smiths gauges, not accurate or reliable.
#6 Re: Oil Pressure sender 3,8
Posted: Fri Jan 23, 2026 4:55 pm
by adam
I have now ordered wet gauge, with nylon pipe as recommended in thread thanks for your help.
Thanks Adam
#7 Re: Oil Pressure sender 3,8
Posted: Mon Feb 02, 2026 6:32 pm
by adam
Hi I lowered gauge panel, I found voltage regulator is connected to oil pressure gauge is this correct for a 63 car
Adam
#8 Re: Oil Pressure sender 3,8
Posted: Mon Feb 02, 2026 8:17 pm
by Gfhug
Adam, have you looked at the wiring diagram? You’ll see the voltage regulator is connected to the oil pressure gauge. Maybe you’re misinterpreting what you are seeing. Check which terminals that wire is going to and maybe it is on the correct one
#9 Re: Oil Pressure sender 3,8
Posted: Mon Feb 02, 2026 8:38 pm
by adam
Sorry I read a post that said its not connected to voltage regulator
Adam
#10 Re: Oil Pressure sender 3,8
Posted: Mon Feb 02, 2026 8:45 pm
by adam
Post I read said it is only used for temp and fuel gauge ,
Adam
#11 Re: Oil Pressure sender 3,8
Posted: Mon Feb 02, 2026 8:55 pm
by Tommd
To be clear, the oil pressure gauge, as original, operates from battery voltage. It receives this battery voltage off the INPUT terminal on the dash voltage regulator, not from the regulated voltage of the dash voltage regulator.
Tom
#12 Re: Oil Pressure sender 3,8
Posted: Mon Feb 02, 2026 9:59 pm
by DWW
That is correct.
#13 Re: Oil Pressure sender 3,8
Posted: Tue Feb 03, 2026 7:51 am
by adam
Thank you for helping me out.I should have looked at the manual
Adam
#14 Re: Oil Pressure sender 3,8
Posted: Tue Feb 03, 2026 9:00 am
by 40GT
If you are fitting as you mention above, a mechanical oil pressure gauge, then the only electrical connection would be for an illumination bulb.
#15 Re: Oil Pressure sender 3,8
Posted: Tue Feb 03, 2026 2:57 pm
by adam
Thanks again for every ones input such a great place to get advice.
Adam
#16 Re: Oil Pressure sender 3,8
Posted: Sun Mar 15, 2026 9:36 am
by adam
Hi I have fitted a wet gauge getting great oil pressure reading so thanks again for the advice.
Adam
