#1 Hub Carrier Damage
Posted: Thu Feb 05, 2026 3:53 pm
Hi all,
Wondered what the considered wisdom is in relation to the damage on one of my hub carriers. Thing looked pretty good when covered in crap, having had it vapour blasted, its a thing of beauty but with a few "warts"
I've just dropped it off at a fabricators and the plan is for him to chop out the damaged area including down to and past the are where the crack extends into recess, then build it back up.
this will work.
Also both my actual hubs are damaged from appearing to have been hit directly with a hammer. I took these apart a while back, I'm pretty certain it wasnt me that did this, one splined drive came out of the hub of its own accord, the other took some persuading but I dont recall whacking it with a hammer. In addition bot water throwers, with damage noted when IRS was still in one piece are not attached to the hub, they simply sit with no fixing to the hub body. Is that correct?
Thanks as ever for the advice/comments.
Kev
Kev
