#1 1965 4.2 LHD FHC Wiring Harness Questions
Posted: Sun Feb 15, 2026 1:15 pm
In searching previous posts on the harness - came across some no longer available images from Christopher Storey and read a post i.e.sorry to note he is no longer with us - he kindly gave me advice and was very helpful...
I'm just starting to fit up the wiring harness and don't want to go too far if I've got it wrong. Before removing the old harness I took many images but now discovering 'not enough' and that some colours on the old one have faded beyond recognition. Also that however my car was previously wired up (and nothing to suggest it's not original) some of the data doesn't chime with the wiring diagram. Have to say I'm surprised that the new harnesses don't have position labels attached - would make life a lot easier...
1) Have I got these two the right way round?
2) Does the harness travel below the central frame and not through the large side apertures?
3) Is the harness correctly positioned between the two hanging tabs? The tabs have been painted - can they be purchased new?
4) Do the left side fuse wires appear correct?
5) Do the right side fuse wires appear correct?
[/u
6) Anything not right here?
[url=https://postimg.cc/grYKy8rh]
Thax in advance
[/u6) Anything not right here?
Thax in advance
