#1 Repro 3.8 indicator switch C21710
Posted: Sat Mar 14, 2026 2:17 am
Having purchased a new indicator switch to replace my original (unfixable) I fitted it.
Only to find that the switch arm rotated in the housing, meaning that I couldn't actuate the switch.
After trying to wick some superglue into the socket without success I removed it (not a quick job) and disassembled it to fix the problem.
With original switches the bottom of the arm is knurled and this provides a firm interference fit into the socket.
BUT. On the repro (as I eventually worked out after some time and swearing) both the socket and the arm are threaded 10/24. Furthermore the threads were loose enough that once it bottomed out it just spun and wouldn't tighten.
So I cleaned out the threads, Araldited it back in place and it now works.
So beware; if yours spins you can just unscrew it from the socket and glue it back in place without having to go to the trouble of removing the switch and disassembling it.
