Could the learned amongst us please advise how I could bench test the wiper motor before re installation in my series 1 4.2 - negative earth
I've tried the single green wire to positive and the earth wire to negative so either this is incorrect or the motor is malfunctioning...
wiper motor bench test
richard btype
Topic author - Posts: 593
#1 wiper motor bench test
3.8 FHC Chassis no: 860403
DOM - 11th April 1962
Also
4.2 FHC Chassis no: 1E32173
DOM - 12th December 1965
Also
#2 Re: wiper motor bench test
Richard, you say it’s a 4.2 but your signature shows a date of April 62. Isn’t that a 3.8 or are you asking for another car?
Have you followed the testing instructions in the manual? Also, what source of power? A healthy battery or a 12 volt supply that may not have the current capability? Just a a couple of thoughts/questions.
#3 Re: wiper motor bench test
There are a few guides in the Forum KB. Try these:
Wiper motor operation DL3 guide: https://www.dropbox.com/s/x7f9u2g650up8 ... l.pdf?dl=1
Wiper Motor DL3 operation and wiring: https://www.dropbox.com/s/hxrf5x1ws1zac ... s.pdf?dl=1
richard btype
#4 Re: wiper motor bench test
Thank you Geoff and David.
It is for another car Geoff, the 3.8 is an original/tidy car, ideal for the Uk. The 4.2 is a LHD ex Canadian car which I'm restoring as a more comfortable/bespoke car for European touring with 3.07 diff/MX5 seats etc. It's not working out as originally planned however which was for the addition of an alloy bonnet, d type wheels, air con etc.
The required work to the shell proved to be far more costly than forseen, the mileage was far lower than thought so it makes more sense for the enhancements to be easily reversible and keep it within the 'originality' side of present values. Bespoke cars appear to be harder to sell on when the time comes....
I'm finding it quite interesting to note the developments between a 62 and 65 series 1 (and will update my signature in due course).
Also
Also
