#1 Tyres fouling mudshield when jacked up.
Posted: Tue Mar 31, 2026 12:25 pm
by phoenix
S1 4.2 WHEN THE FRONT WHEELS ARE OFF THE GROUND THE TYES FOUL THE MUDSHIELD ON FULL LOCK. IT IS A NEW BUILD WITH CORRECT TYRES ETC. WHEN ITS ON THE GROUND ITS OK . IS THIS NORMAL THANKS
#2 Re: Tyres fouling mudshield when jacked up.
Posted: Tue Mar 31, 2026 7:01 pm
by Gfhug
DON’T SHOUT !!!
#3 Re: Tyres fouling mudshield when jacked up.
Posted: Wed Apr 01, 2026 12:07 pm
by rfs1957
I have noticed - since the beginning - that our friend barks out orders in this manner, presumably using his telephone keypad for brevity, with no heed to manners nor subtlety, so I am assuming there must be some Paid Subscription version of the Forum where one is Entitled to obtain answers from the Staff.
And maybe CAPITALS get a subscriber a priority reply.
As I’m not one of the Staff I will hold my counsel.
#4 Re: Tyres fouling mudshield when jacked up.
Posted: Wed Apr 01, 2026 12:34 pm
There is no problem posting in capitals.....its perfectly clear and polite with a thanks.....dont forget some of us are getting a bit older we just type away....If you dont want to reply to the question you don't have to.....Steve
#5 Re: Tyres fouling mudshield when jacked up.
Posted: Wed Apr 01, 2026 4:06 pm
by Gfhug
Oh dear, it looks like me and Rory are in the naughty corner :bigrin:
Is this classed as topic drift, too!
#6 Re: Tyres fouling mudshield when jacked up.
Posted: Fri Apr 03, 2026 2:04 am
by Geoff Allam
In response to the op's question it is perfectly acceptable. The rear tires will also sometimes rub on the bump stops at full droop. Unless you are getting impressive air going around a very tight corner you will never experience the problem in real life.
#7 Re: Tyres fouling mudshield when jacked up.
Posted: Mon Jun 08, 2026 4:08 pm
by dougal
I'm not so easily offended by the use of capital letters. maybe i dont have such sensative hearing.
Anyway back to the subject in hand.
can i just confirm you have proper 185VR15 tyres on the car. I will only really consider Pirelli Cinturato, Michelin XVS or the Dunlop SP Sport as proper tyres all the other ones are modern pretenders.
I think there are 2 possible options; assuming you have the right tyres:
1/ you have the wrong wheels? you might have other 15" wheels with wider rims where the extra width is outbound and the cause of rubbing. you may also have the wrong offset where the wheel centre is spoked into a different place in relation to the rim.
2/ I have historically come accross an e-type where the owner swore blind it was oriinal and the tyres we supplied rubbed and were the wrong size. he came to see us and on inspection i looked inside the wheel arch and the wings had been fitted at the wrong angle and they rubbed.
