My 66 Auto has a missing Carb linkage part that connects the main throttle shaft to the kick down shaft, the number is C25804, does anyone know the dimensions for this or could someone measure this rod for me ( outside to outside will do ), the part is almost the same as the 3 linkage rods to the carbs, but it probably won't have the kink.
Mine was presumably lost at some point and replaced with a bent piece of brake pipe, I made an adjustable one ( that isn't bent double to keep it in place ), but it would be nice to have this at the correct length to help with kickdown adjustment. The car has no working kickdown, but a shift to " L " does the trick for now.
Thanks in advance, Sean.
S1 S2 Auto BW linkage help
#1 S1 S2 Auto BW linkage help
Sean
S1 2+2 1966 BW RHD
XK120 1954 comp LHD
S1 2+2 1966 BW RHD
XK120 1954 comp LHD
