#1 New clutch issue, Series II
Posted: Sun Apr 05, 2026 8:57 pm
As you may or may not recall, several years ago my Series II had a clutch issue where the throw-out bearing would not release completely..
Result.. remove engine and transmission, new clutch disk, pressure plate, throw-out bearing.
About a year later, the pressure plate began intermittently making this horrendous clanking noise..
Now, about two years later, the release bearing is intermittently making a clicking noise, but only when the clutch is engaging, not fully released, not fully engaged. Take a listen..
Any ideas? I'm thinking some type of fastener holding the release bearing to the fork is flopping around and hitting the pressure plate?
Thanks!
Howard
Thanks!
Howard
