#1 Washer jet replacement..
Posted: Mon Apr 06, 2026 5:39 am
by Paul bow
Hi guys, unbelievably both the directional adjustment nozels have broken in the main body of my washer jets.
Only 2 years old! Should have used the 60 year old originals.
looks like a pig of a job, anyone got any advice on fitting them or maybe a clever remedy?
Thanks in advance
#2 Re: Washer jet replacement..
Posted: Mon Apr 06, 2026 8:06 am
by johnetype
Use jets from a 2+2 that have two jets each.
Use silicon rather than PVC washer hose.
Find someone with small hands to help.
Connect the hose to the jet and feed the hose in from outside the car. Slide the nut back up along the hose from the inside so the hose guides the nut onto the end of the jet.
Consider fitting a small O ring to the base of the washer jet to help seal it to the scuttle.
#3 Re: Washer jet replacement..
Posted: Mon Apr 06, 2026 8:30 pm
by Paul bow
Thanks John, can all that be done with the dash still in place ?
#4 Re: Washer jet replacement..
Posted: Tue Apr 07, 2026 4:58 pm
by tim wood
viewtopic.php?f=11&t=21604&p=176353#p176353
Have a look through this, plenty of other posts on the forum re this
