Before I delve into the electrics again is there any reason the car should now only run on 5 cylinders after fitting a Dynamator?
I can't think of one, but I am a little poorly educated when it comes to the electrics.
I got sick of trying to work out why the generator wasn't charging the battery.
Dynamator now car runs on 5.
#1 Dynamator now car runs on 5.
#2 Re: Dynamator now car runs on 5.
Hi Andrew.....no reason as far as im aware....you can run the car just on the battery.....many have when touring and the dyno/alternator packs up.....Steve
#3 Re: Dynamator now car runs on 5.
Follow up. #5 plug lead pulled; no difference in rpm. Plug removed; oiled up. Replaced. Car runs perfectly.
We'd been moving the car in and out of the garage a lot while working on Dave's ND. Too much choke fouled the plugs.
#4 Re: Dynamator now car runs on 5.
Thanks for the update....Steve
