Hi, do the headlamp scoops on a series 2 car have any sealing between the scoop and the bonnet along the line of pop rivets? Mine seemed to have something like a flexible sealer between the faces.
I presume that the rubber seal sits on top of the scoop.
Headlamp scoops series 2
Stevejaguar
Topic author - Posts: 177
#2 Re: Headlamp scoops series 2
As they left the factory, no, no sealant but in today's world in the fight against corrosion you'd be mad not to refit the scoops without a thin layer of sealant to keep moisture out of the inevitable mismatches between the scoops and bonnet.
1969 Series 2 FHC
1969 Series 2 FHC
#3 Re: Headlamp scoops series 2
Simple black gutter sealant from screwfix about £3 a tube, best £3 you ever spent! Never goes hard, easy to wipe clean with a little panel wipe to make a really neat seal no one can see, then with what ever is left (plenty) use it between the front/rear window rubbers, you’ll never get a leak there again! And it don’t stick so still a doddle should you need to remove them.
S1 2+2 manual. (Sold)
