#1 +30 piston rings: available or not?
Posted: Mon Jun 08, 2026 11:34 am
My 4.2 l engine was rebored to +.030 thou in the past. I found the cylinders in very good condition, as the pistons, so decided just to change the rings. I wanted to keep away form the ultimate grinding (+0.040) if not resleeving. Alas, it seems difficult to find +0.03 rings, if not impossible.
SNG has the FZ60130 reference, sold per unit. This is not an issue to me, I just have to buy 6 of them
They are said "+0.03" but it is not clearly stated for what engine they are, so I bought only one kit just to check.
I found that I have to slightly trim the compression rings in length for the right gap in the cylinder bore. More importantly, the oil ring was impossible to fit in its groove.
Does anyone here know this FZ60130 kit?
Does anyone know where I could find genuine +0.03 rings?
If not, does it make sense to only change the compression rings and keep the old oil rings?
Thanks in advance for helping.
