#1 Sudden total brake loss
Posted: Fri Jun 12, 2026 8:58 pm
by Landcrab
Hello, I have a very strange behaviour on a 1966 2+2. The owner of the car told me that the car at a few occations he had lost brake preassure and he had to pump the pedal a few times. I was picking up his car and there was nothing wrong with the brakes. I changed the master cylinder the flexible hoses and the fluid.
Went out for a test drive and everything was good. Decided to drive the car back to my friend and the return trip is 20 minutes country roads and finally 10 minutes motorway. I was braking slightly before turning on the motorway, all fine and 10 minutes later when turning off there was zero brakes. There was the emergency brakes that the reaction valve sort out but absolutely nothing else and that is the last 10mm of the pedal movement. Went back to a friends house and had some coffee and 30 minutes later a few pumps on the pedal and the brakes are back!!! I spoke to the owner and he then said that the few times he had this fault was always after motorway driving.
New oil
New hoses
New master cylinder
No fluid loss in any of the 2 containers.
Absolutely no sticky pads or roll resistance at any time.
Could the vaccuum do something like this?
Or what could possibly cause this?
Is there anyone that have had this odd behaviour before?
Greatful for any suggestions
Best Regards Johan
#2 Re: Sudden total brake loss
Posted: Sat Jun 13, 2026 3:29 am
Is something getting hot?
Sounds like brake fade due to brake fluid boiling.
#3 Re: Sudden total brake loss
Posted: Sat Jun 13, 2026 6:28 am
by Landcrab
No nothing out of the normal when I checked the brakes 30 seconds after the failure
#4 Re: Sudden total brake loss
Posted: Sat Jun 13, 2026 7:51 am
Do you mean a loss of servo assistance brakes or a total loss of brakes.....there are very good drawings in the service manual that describe the braking system......I cant see a situation where this is connected to driving....you should be able to recreate any issues in the garage......i would be looking at the reaction valve area.........Steve
#5 Re: Sudden total brake loss
Posted: Sat Jun 13, 2026 8:45 am
by malcolm
I had something similar, although not as dramatic, and had a new servo unit. All fixed.
#6 Re: Sudden total brake loss
Posted: Sat Jun 13, 2026 12:49 pm
by Tommd
Johan, based on what you describe, I would suggest the MC first, which you already addressed. Next brake fluid, which you addressed. Last the slave/servo cylinder which fixed Malcom's. My only further question would be, if it is the slave/servo, I would be expecting the one reservoir to fill and the other empty, although it would not be "required."
Tom
#7 Re: Sudden total brake loss
Posted: Sat Jun 13, 2026 3:05 pm
by Landcrab
Thanks for the suggestions, It was a total loss of all the brakes and not just the servo assistance.
I will change the servo unit as well, but I’m wondering if no braking in combination with constant vacuum for a longer period could reverse all the caliper pistons? This of course due to some kind of failure in the servo cylinder.
It’s s really nasty fault and I have only had the same experience on a Mini with one line system so that was a no brainer.
#8 Re: Sudden total brake loss
Posted: Sun Jun 14, 2026 1:49 pm
by dlgis
Might be worth checking your brake lines to the brake fluid reservoir are not pinched. I had complete brake failure on the Dartford bridge after 50 miles of motorway travel. One of the brake lines had a bit of a kink in it causing the fluid to boil. Quickly unkinked and all back to normal. πŸ€”
#9 Re: Sudden total brake loss
Posted: Mon Jun 15, 2026 1:22 am
by Mhminnich
Are the brake heat shields on place? I could imagine an overheating issue of the servo.
#10 Re: Sudden total brake loss
Posted: Mon Jun 15, 2026 10:45 am
by Landcrab
I will check, could possibly be a reason. Strange only why it suddenly would start to be an issue without any sudden changes.
#11 Re: Sudden total brake loss
Posted: Fri Jul 10, 2026 6:09 am
by Landcrab
Sorry for late reply, I have found the problem. It was the servo. When I took it down it had 3 dl of oil behind the cylinder. When I then asked the owner about filling up the reservoir he said that it was only small amounts a few times which he didn’t mention the first time and this had made the fault finding a totally different thing. Anyway everything is working fine now.
Best Regards Johan
#12 Re: Sudden total brake loss
Posted: Fri Jul 10, 2026 11:25 am
by RICHOT
πŸ‘πŸ‘πŸ€žπŸ€žπŸ‘πŸ‘
