#1 Thinner than usual valve pads
Posted: Sat Jun 13, 2026 7:18 pm
I would like expert's opinion about the minimum thickness of valve adjusting pads.
As a matter of fact, after regrinding of the valve seats, and change of valves for new, I measured that the normal pads, minimum thickness of which is 0.085" = 2.16 mm, would be too thick for my engine. Using a thin dummy pad, I inferred that I would need pads as thin as 1.34 mm. The thicker one should be 2.01 mm.
My question is, assuming I find someone able to machine such pads from commercial ones : is there any inconvenience running an engine with 1.34 mm thick pads?
Thanks for your thoughts.
