Brake pad knock - off - 68 S1.5
Threadbear
#1 Brake pad knock - off - 68 S1.5
Post by Threadbear » Wed Jul 01, 2026 4:54 pm
I am suffering from a long brake pedal, which is fine after the first application each time. When off the brakes there is slight play in the front pads, and i can see a small gap, .010" maybe, on each pad. The Dunlop cylinder assemblies are about 4 years old, 2000 miles at most, new fluid and the pads are new EBC, which don't engage with the standard pad retractors. Is it normal that the pistons would retract a bit, or is it time for new seals? Or maybe someone could make another suggestion. Thanks
RICHOT
#2 Re: Brake pad knock - off - 68 S1.5
Post by RICHOT » Wed Jul 01, 2026 8:15 pm
Warped brake discs?
1950 XK120 (now sold)
1953 XK120 (now sold)
1965 S1 E Type DHC (ex 2 BBC)
Threadbear
#3 Re: Brake pad knock - off - 68 S1.5
Post by Threadbear » Thu Jul 02, 2026 1:57 pm
Thanks, the discs are not very old andxare not warped. The pad retraction happens even stationary. I can press the brake pedal a couple of times and its fine. When I then look at tha pads there's already a gap
