Hi all, I am replacing the throttle linkage bush, in the bracket on the bulkhead under the wiper motor. I am attempting to remove the bolts that hold said bracket to the bulkhead, and it appears there are nuts on the other side. Now from memory, these had captive nuts, can anyone confirm please?
Any other ideas to replace the bush easily? I was thinking to make a diagonal cut in the bush, and feed it in??
Thanks, Steve.
THROTTLE LINKAGE BOLTS
Stevemorris
Topic author - Posts: 90
#1 THROTTLE LINKAGE BOLTS
1965 Jaguar ‘E’ Type FHC
#2 Re: THROTTLE LINKAGE BOLTS
They are captive nuts on my 1965 series 1,
1965 series 1 ots
1972 triumph spitfire
2016 Caddy van
2016 Caddy van
