How to adjust tex door mirrors???
jamesmustain
#1 How to adjust tex door mirrors???
Post by jamesmustain » Fri Jan 22, 2021 10:57 am
Hi All, I have a Tex door mirror on my car. When it’s in my preferred position for driving it flops back to near parallel with the door above 40mph. Anybody had the same problem and found a fix?
Thanks!
#2 Re: How to adjust tex door mirrors???
Post by malcolm » Fri Jan 22, 2021 2:11 pm
Have you got a photo of the mirror? That would help. With my ones you could take them apart (although it wasn't obvious) and there was a screw you could tighten inside
#3 Re: How to adjust tex door mirrors???
Post by Gfhug » Fri Jan 22, 2021 5:53 pm
Depending on just which mirror you’ve got, one attached to the door panel below the window?
I ended up making a hard plastic washer to put between the mirror and arm and this gave both a greater movement range but also a firmer hold of the position.
Bigcatfrankie
#4 Re: How to adjust tex door mirrors???
Post by Bigcatfrankie » Fri Jan 22, 2021 6:02 pm
I had the same problem with a floppy mirror!.........it was the swivel socket ball that was too loose. I solved it by carefully smearing Araldite epoxy glue around the visible parts of the ball and then using a hairdryer to make the glue more runny so that it seeps into the hidden bits.
You'd think it would lock it up completely but it seems to have worked...........certainly no floppiness now!
Tim
1970 ex.U.S. Series 2, 2+2, in course of restoration
1965 Austin Healey 3000
#5 Re: How to adjust tex door mirrors???
Post by PeterCrespin » Sat Jan 23, 2021 12:43 am
jamesmustain wrote: ↑
Thanks!
Equal parts crushed sildenafil tablets and valve grinding paste ought to do it.
NadiaEira
#6 Re: How to adjust tex door mirrors???
Post by NadiaEira » Wed Jul 22, 2026 9:09 am
I fixed the issue by applying Araldite epoxy to the exposed areas of the ball and using a hairdryer to thin the glue, allowing it to flow into the internal crevices.
Marcus2571
#7 Re: How to adjust tex door mirrors???
Post by Marcus2571 » Mon Jul 27, 2026 3:17 pm
:lol:
PeterCrespin wrote: ↑
Thanks!
