Headlamp scoops series 2
Stevejaguar
#1 Headlamp scoops series 2
Post by Stevejaguar » Mon Aug 31, 2026 9:10 pm
Hi, do the headlamp scoops on a series 2 car have any sealing between the scoop and the bonnet along the line of pop rivets? Mine seemed to have something like a flexible sealer between the faces.
I presume that the rubber seal sits on top of the scoop.
johnetype
#2 Re: Headlamp scoops series 2
Post by johnetype » Mon Aug 31, 2026 9:24 pm
As they left the factory, no, no sealant but in today's world in the fight against corrosion you'd be mad not to refit the scoops without a thin layer of sealant to keep moisture out of the inevitable mismatches between the scoops and bonnet.
1969 Series 2 FHC
