Headlamp scoops series 2
Stevejaguar
#1 Headlamp scoops series 2
Post by Stevejaguar » Mon Aug 31, 2026 9:10 pm
Hi, do the headlamp scoops on a series 2 car have any sealing between the scoop and the bonnet along the line of pop rivets? Mine seemed to have something like a flexible sealer between the faces.
I presume that the rubber seal sits on top of the scoop.
johnetype
#2 Re: Headlamp scoops series 2
Post by johnetype » Mon Aug 31, 2026 9:24 pm
As they left the factory, no, no sealant but in today's world in the fight against corrosion you'd be mad not to refit the scoops without a thin layer of sealant to keep moisture out of the inevitable mismatches between the scoops and bonnet.
1969 Series 2 FHC
Paul bow
#3 Re: Headlamp scoops series 2
Post by Paul bow » Mon Sep 07, 2026 2:53 pm
Simple black gutter sealant from screwfix about £3 a tube, best £3 you ever spent! Never goes hard, easy to wipe clean with a little panel wipe to make a really neat seal no one can see, then with what ever is left (plenty) use it between the front/rear window rubbers, you’ll never get a leak there again! And it don’t stick so still a doddle should you need to remove them. 👍
S1 2+2 manual. (Sold)
