K-Line Valve-guide inserts for XK engines
norman m. macleod
#1 K-Line Valve-guide inserts for XK engines
Post by norman m. macleod » Sat Mar 19, 2011 1:25 pm
Hi there all,
Has anyone had experience in the installation of K-Line valve-guide inserts for the XK engine.....? And possibly a UK or Australian supplier of the kits....?
Thanks,
Norman Western Australia
1967 S1 2+2
38E
Post by 38E » Sat Mar 19, 2011 3:04 pm
I have no experience with that particular make but I did make the bads mistake of having bronze liners installed in my 3.8 engine years ago when I restored the car.
More recently when I was doing some engine work, I had the valve guides changed for the newer type, solid silicon-bronze, I think and I also added inlet valve seals together with the more modern hardware. This has seemed to completely cure the smoking on start-up (from the inlet valves leaking).
There are some pictures of the work and the parts I used here:-
http://www.jag-lovers.org/snaps/snap_vi ... 1196733326
Clive, 1962 Coupe 860320
(sold)
