Heuer wrote: My only disappointment is the fact VSE fully rebuilt the engine and carbs in 1999 but after 33,000 it has required new crank bearings, carb rebuild, rear rope seal and the head overhaul. I know I drive the car fairly hard at times but it does make me wonder whether these engines are reconditioned with the expectation that few will do more than 600 miles a year.
My home-rebuilt engine is on 90K and rising, 6 of those being on my build. The engine was in spec with everything from bore sizes, journal sizes, even valve stem sizes well inside wear limits. There are two differences I can think of that account for the vastly different lifespans - and I would not expaect mine to look like yours until maybe 30K of hard driving like you've done:
1) The first 84,000 miles were done in an XJ6 automatic. By far the majority of 4.2s will have spent their life on an auto box and therefore the increased crank whip will not be an issue as autos aren't thrashed.
2) I assume my engine has had standard air filtration all its life, it certainly does at present in the E and I assume it did when it was in the Series 3 XJ. I have a feeling you've used ITG or some other custom filter arrangement? This is the biggest reason for the general wear I'm sure, although I would expect it to affect your bores too eventually, which it seems not to have done. I could believe they've left the rings and pistons alone but did they check bore wear? Microscopic dust particles are mopped up by the oil and turn it into grinding paste. Regular changes help mitigate this and I'm obviously exaggerating to some extent with 'grinding paste' comment, but it definitely wears engines out faster to have 'sports' air filtration compared to boring old standard filtration.
The rear crank seal is one of those things I suspect. If it was truly peeing out then no wonder you changed it. If it was just dribbling a bit, othersm ight havel eft it for 90,000 miles not getting any worse. I'm surprised they left the standard breather on a race-spec engine or close to. It will have stressed all engineselas right enough at high revs.
Are you saying CMC rebuilt your engine using the big end shells that were in it? I would find that astonishing given the state of your mains. If they replaced the big ends then it has needed new big ends as well, not just mains. For the minimal extra trouble and cost I'd have re-ringed it and glaze-busted it myself <shrug>
