#1 "P" clips
Posted: Mon Jun 20, 2011 10:03 pm
by vipergts
Anyone happen to know where I can get "P" clips from.
I bought some a year or so ago and can't remember where from.
I don't want the horrid rubber surrounded jobbies bit the gold zinc plated ones.
For anyone that is not familiar they're the clips that generally hold the wiring harness in place.
Posted: Tue Jun 21, 2011 6:47 am
by ChrisC
Posted: Tue Jun 21, 2011 9:33 am
The looms should be held in place underbonnet etc by strapping which is slotted and punched and which has studs which go through the holes . The beauty of these is that you can undo and/or adjust them easily. Kits sufficient to do the entire car available from the usuals including Hutsons and cost bugger all
Posted: Tue Jun 21, 2011 1:05 pm
by vipergts
christopher storey wrote:The looms should be held in place underbonnet etc by strapping which is slotted and punched and which has studs which go through the holes . The beauty of these is that you can undo and/or adjust them easily. Kits sufficient to do the entire car available from the usuals including Hutsons and cost bugger all
Thanks ChrisC....Great work
Christopher.......The straps you mention I have used on my V12. They may or may not also use them on the 6 cyl cars but P clips are also used in many places
Thanks Guys
