hi, following my suspension rebuild i need to reset the castor and camber.
if i ask a garage to determine the current camber setting by gauge can I then measure the shim thickness and convert into degrees of change?
not sure if this makes sense but I am trying to avoid the cost of paying for a specialist to move these shims about.
any thoughts?
regards to all
Tim
camber setting
I'm pretty sure Haynes lists the camber change per shim thickness, or try searching on Jag Lovers E-type forum where this has been covered many times.
John '62 S1 OTS (now sold)
#3 Re: camber setting
Tim,tim wood wrote:hi, following my suspension rebuild i need to reset the castor and camber.
any thoughts?
regards to all
Tim
That's exactly what I did. Took it to a laser alignment shop, got a printout of the readings and added/removed shims to get the correct figures. The only 2 that needed adjustment were castor (front) and camber (rear).
The service manual states that each 0.020" shim at the rear changes camber by 0.25 deg, there is probably a similar description about the front. The front castor changes by 0.4 deg per turn of the fulcrum shaft.
1963 OTS
