I have a series 3 V12.
There is a squeeking type noise coming from the rear end. It could be from a hub but I'm not sure. Sounds a bit like a worn bearing but the sound dissapears when I take the power off and coast along. When I put accelerator down sounds returns. Could this be a drive shaft problem or a wheel bearing? Or am I barking up the wrong tree. I have got a slight leak from the prop shaft seal to the diff, although the seal has been replaced recently. Mechanic said there was some wear around the seal area that could be allowing seapage. Don't know if its connected.
Any thoughts welcome.
Cheers Mike
