Hmm... after many tries I still cant insert the brass horn push rod fully into the steering column. I know there is a spring contact at the bottom of the column but I cant see it so presumably it is internal.
Any tips or tricks please or I am just unlucky and should keep trying... it looks so simple but I am getting frustrated with it and thats the time to stop and ask for advice....
Series 1 - horn push rod - re-inserting?
#1 Series 1 - horn push rod - re-inserting?
1964 FHC 4.2
Chris
This thread may help: http://etypeuk.com/forum/viewtopic.php? ... &start=460
You should be able to just push it in. It makes contact with a spring pressured brass nipple in the column.
Ahhhh - i have some pieces missing from the rod.... damn. Time to go sorting through my box of odd bits and pieces
1964 FHC 4.2
I got all the parts I needed from SNGB.
John '62 S1 OTS (now sold)
I need part number 13 in the picture below is that piece in the kit?
1964 FHC 4.2
Yes, I think so, but if that is all you need just buy it separately (C16879) - listed at ?7.49 by SNGB.
Doh - never thought of looking up the code as an individual item thanks....
I have now got the rod into the column so I know it fits - it just to buy the insulator sleeve.
1964 FHC 4.2
