#1 head light mystery
Posted: Tue Oct 25, 2011 9:13 am
by snowdmc
Hi All,
When i bought my car a few weeks ago i hadn't noticed that the dipped headlight on the drivers side was blown, no problem as they were sealed beam units and i was keen to upgrade to H4 halogen lights instead.
So after swapping out both units, the headlight on the drivers side is still not working(dip) (brand new bulb) but the full beam works ok, fuse is intact - i'm a little bit stumped as to what the issue is, i checked the voltage and registers with 12v at the terminal, but this drops to 2v once i connect the bulb. i thought it might be a bad earth, but the full beam works fine and they share the same earth connector.
Is there a headlight resistor or similar on each side that may have blown, like the old motorbikes used to have?
Help greatly appreciated, driving home on 1 headlight was not fun, but was brighter than 2 sealed units tho
Posted: Tue Oct 25, 2011 9:15 am
by snowdmc
forgot to say everything is fine on the passenger side, perhaps the previous unit being blown should be a telling indication to something?
Posted: Tue Oct 25, 2011 11:15 am
It is likely to be corrosion on one of the connectors, probably on the right hand headlamp side of the double one . I cannot remember whether the high beam is blue /white or blue/red , so check both
Posted: Tue Oct 25, 2011 11:30 am
by snowdmc
thanx, i ordered new connectors when i bought the lamps, so will wire these in and let you know how i get on
Posted: Tue Oct 25, 2011 11:37 am
I've checked, and blue/white should be the main beam
Posted: Fri Nov 11, 2011 3:31 pm
by snowdmc
thought i should post a quick update, car is currently at the garage so cannot do any work on it yet, have been told that the loom plug on the passenger side is notorious for causing light problems, so when i get it back, will give it a wiggle and go from there :)
Posted: Fri Nov 11, 2011 5:01 pm
by 1954Etype
snowdmc wrote:thought i should post a quick update, car is currently at the garage so cannot do any work on it yet, have been told that the loom plug on the passenger side is notorious for causing light problems, so when i get it back, will give it a wiggle and go from there :)
Wont be the plug if only one is working. It has common feeds to the headlights (b/w for main b/r for dip) which is split inside the bonnent nose.
Posted: Sat Nov 12, 2011 10:39 am
by snowdmc
Ah I see thanks for that, how accessible is the wiring in the nose?
Posted: Sat Nov 12, 2011 1:20 pm
by 1954Etype
snowdmc wrote:Ah I see thanks for that, how accessible is the wiring in the nose?
You have to remove the sugar scoops. Remove the LHS one first as that is where the junction box is.
