#1 Polyurethane foam moulding
Posted: Wed Nov 16, 2011 8:24 pm
As my car has a 5-speed conversion and a custom-made gearbox cover, there's rather a lack of sound deadening between the gearbox and the interior - just the metal cover and the console and a thin layer of Koolmat.
One small winter project is to increase sound deadening in this area. Some of you may say "its an OTS, why bother" and you may be right but I'd like to see if I can suppress whining in intermediate gears. The whining is not excessive and (according to CMC at least) is "normal" for this box, but I do notice it.
Anyway, I have been experimenting with flexible polyurethane foam - the sort where you mix the two liquids (polyol and isocyanate), pour them into a mould, and watch the foam expand and then set. I used thin plastic bags to sit in the gaps between box and upper tunnel areas (underneath the gearbox cover) and so far so good - it makes nice chunky pieces of PU foam which are moulded to the shape of the gearbox casing and sit happily in place but are flexible enough to be removed from the top to access filler plugs, speedo drive etc. I'm using a mix designed to give a medium-density foam.
I'll probably cast some more foam to fit between gearbox cover/tunnel and the underside of the console, and then see how much (if any) reduction in noise transmission I can notice in the spring, then report back!
Has anyone else done anything similar?
