Door Shuts - Advice on seals
MButchers
#1 Door Shuts - Advice on seals
Post by MButchers » Tue Dec 11, 2007 6:48 pm
Hi Guys - trying to make the door shut lines a little better on my fhc. Basically the door rubber seals seem to be too bulky to allow the doors to shut with good alignment. If I remove the seals, the doors shut almost perfectly, once the catches are adjusted.
The seals could do with renewing, and I was wondering if it's possible to fit lower profile seals, and if so, where they would be available.
It may be the case that the seals are not the correct type as fitted.
Any advice very much appreciated.
