#1 v12 5.3 conversion to v12 6.0 fuel inj
Posted: Sat Jan 28, 2012 11:03 am
by club3999
hi to all at etype uk can any one give me some advice on converting a 5.3 carb to a6.0 fuel injection in to my e-type mk3 2+2 i have the donor car 1994 aj12 please help thanks kevin my email is
kevthegolfer@yahoo.com
Posted: Sat Jan 28, 2012 9:14 pm
by PeterCrespin
I assume your car has the Marelli distributor and is an XJ40 square shape? It could be the distibutorless rounded-shape X300 model, as that was the changeover year.
Did you get hold of AJ6 Engineering as discussed today on the phone?
Posted: Mon Jan 30, 2012 1:36 pm
by Woolfi
I have heard from a car-machanic in Germany, which has done some of theses swaps, that he has used allways the injection of the 5,3HE on the 6,0 motor. The 6,0 injection has problems to work correct, if working without the original automatik-gearbox. Roger Bywater has "reprogrammed" the electronic "brain" of a 5,3-injection to use with a 6,0 motor.
Because of this I have done the swap to the 6,0 l motor with the 4 Strombergs from the 5,3 motor. After some month of "debugging" this combination is running very well.
Regards Wolfgang Gatza
The car of a friend with a 6,0 motor
Posted: Wed Feb 01, 2012 10:32 am
by Peter Collins
i am behind you a 100% on converting to fuel injection .I have got 90% of a fuel injection XJS 5.3 ,inlet manifold , wiring loom , ecu ect; if you are interested.
Posted: Wed Feb 01, 2012 11:44 am
by Woolfi
Can you explain me, why you are converting to fuel injection ?
I had the same idea for long time, would have been willing to spend 4000 Euro for this projekt, but stopped it.
Posted: Mon Feb 20, 2012 8:22 pm
by tonyd
Wouldn't it be easier and produce a better result to use Megasquirt?
Posted: Mon Feb 20, 2012 9:07 pm
by Woolfi
I think to make a conversion with a megasquirt running well is not a easy job. If you are using megasquirt you must have knowledge in electronics. I know some EV12 which have been equiped with a injection. Most of the cars have minor problems.
