I wonder if anybody has a close up photo they could load up that shows the above bracket, preferably on the block. I've scanned through XKE data without much luck. Or anybody in the Preston area with a car I could look at?
I'm just trying to sort the intallation of a C42 (later type) and as the one I have is from a collection of parts my Dad (sadly no longer around to ask
Also, to get the belt on, the casing fouls the centre mounting stud on the block, I should say there is no tensioner on this set up.
I've no problem turning up a boss/spacer and brazing it in the appropriate place as necessary, just would like to make sure I'm up the right tree to start with.
Thanks in anticipation.
Mike
