Hello,
I'm rebuilding an xk engine for my 68 series 1.5 FHC but not sure how to install the distributor drive shaft at the correct angle. Can anyone please provide a definite instruction?
Double thank you,
Graham
engine rebuild Distributor drive shaft installation ?!!
Bristoletype
Topic author - Posts: 9
Bristoletype
#2 update
Hello again,
I've installed the distributor drive and checked position by trial fitting the distributor with the rotor arm lined up to the no 6 piston spark plug on the dizzy cap. that should do it!
Graham
Graham
