The wiring on my series 2 ignition switch has become loose - I'm now trying to marry up all the wires back onto the switch and unsure on the 1-2-3-4 connections in the wiring diagrams Vs the R 15/54 30 50 connections as labelled on the back of the ignition switch.
I assume I have a lucas switch with a ancillary/redundant no. 4 connection?
Any help on this would be most appreciated.
Ignition Switch wiring
I've found this information in the dropbox library. It's in a side note on the wiring diagram (top left!)
http://dl.dropbox.com/u/8496016/S2%20Se ... uments.pdf
Should have looked first! Many thanks for the great library of data.
