Footrest
robsimons
#1 Footrest
Post by robsimons » Wed Mar 14, 2012 2:59 pm
1969 Series II, am putting it back together, and found a plywood board that I cannot determine its use / place. It is about 12" square with a top that has something akin to a rectified sine wave on the top (two humps with an upward smile between). Any thoughts?
Rob Simons
Post by Heuer » Wed Mar 14, 2012 3:16 pm
Passenger toe-board to fit in footwell. Allows those with shorter legs to brace themselves better because of your driving!
More info: http://forum.etypeuk.com/viewtopic.php? ... t=footwell
From the Forum Knowledge Base:
Footrest Cutting Plan: https://www.dropbox.com/s/p52d5y1onnkqo ... t.zip?dl=1
robsimons
Post by robsimons » Thu Mar 15, 2012 12:07 am
Thanks a lot, you were right on, and my shorter wife will appreciate the foot rest, however my son will have to remove it! Next is a painted on one side kind of a trapezoid piece of metal with some washers that look like the bonnet washers that sports 2 cutouts on the edge (smallest side) that look like they might be reliefs for hoses.. (I have AC from the factory). Thoughts on that? And a piece of vinyl that is T shaped. the top cross is longer than the shorter fatter vertical piece. the 'right' side has a curvy cut. thanks for your thoughts!!!
Rob Simons
Post by Heuer » Thu Mar 15, 2012 10:09 am
Please post some pictures as it would help immensely. Instructions here: http://etypeuk.com/forum/viewtopic.php?t=1666
robsimons
Post by robsimons » Thu Mar 15, 2012 5:58 pm
The link below is to my 3 pieces of unknown origin... insulation, vinyl, sheetmetal, from under the bonnet I suspect. http://s1078.photobucket.com/albums/w481/robsimons69/ Thanks for looking. and your help.
Rob
Rob Simons
Post by Heuer » Thu Mar 15, 2012 6:02 pm
Rob
If you hover your mouse over your Photobucket photo you will see a box with four options. Click on the 'IMG Code' one (third down) and paste the copied link into your post like this:
You also asked about FHC trim so check out this excellent thread: http://etypeuk.com/forum/viewtopic.php? ... &start=280
robsimons
Post by robsimons » Thu Mar 15, 2012 6:14 pm
Thank you for your instructions, I very much appreciate the help.
Rob
Rob Simons
