Hi Folks,
Been greasing the front propshaft U/J-had to 'lift' the glued-down carpet on the tunnel to access the huge rubber grommet. Should my car -'64 FHC-have the popped down 'carpet flap' on the passenger side to allow access to the grommets?
Thanks,
David
3.8 (late) tunnel carpet
david muir
Topic author - Posts: 255
My late 64 FHC did not have a flap with poppers but it did have glue at the top where it would fit under the centre console. I never re-glued it when it was periodically removed and it was fine.
Not sure if that answers your question but perhaps sharing how my car was enables you to make a decision
1964 FHC 4.2
david muir
#3 '65 Carpets
Thanks Chris...........anyone else know if these cars are correct as is?
David
David
