How long are your needles ?
tim wood
#1 How long are your needles ?
Post by tim wood » Sun Jun 10, 2012 6:09 pm
Hi, I'm setting up my SU,s and have used a depth gauge to set the jet depth at 65 thou as seemingly I read this somewhere. I thought that if jet depth was so critical then how about needle length . So I measured these. The amount protruding from the base of the piston varies by about 29 thou across all three.
I could spend time equalising this but will it be worth the effort?
Any advise or thoughts welcome.
Tim
Post by Heuer » Sun Jun 10, 2012 6:28 pm
Tim
There are several excellent SU instructions in the Forum Knowledge Base>Manuals, Technical Guides; I particularly like the period SU Tuning Guide.
Post by christopher storey » Sun Jun 10, 2012 8:50 pm
It is absolutely vital that the needles are set correctly. The shoulder of the needle should be exactly flush with the base of the piston
Nick
Post by Nick » Sun Jun 10, 2012 9:11 pm
I recall that the needle diameters are measured from the shoulder not the pointed tip of the needle, so you should set all 3 with the shoulder flush.
Nick
1965 S1 FHC
tim wood
Post by tim wood » Mon Jun 11, 2012 6:45 pm
All, thanks for your replies. The older needles did indeed have a shoulder which made things easier but the later ones have a groove. Thus the question is:
To the centre of the groove or the edge. We are only talking thousandths so it may not be critical?
Nick
Post by Nick » Mon Jun 11, 2012 8:19 pm
Tim,
The lower edge of the groove should be flush with the base of the piston (from Jaguar service manual). You need to equip yourself with some books !
Nick
1965 S1 FHC
tim wood
Post by tim wood » Tue Jun 12, 2012 4:22 pm
Nick, I have loads of books but this later needle didn't feature in any of them. However to complete my education and add to my resource library I have purchased (and it's been delivered today) the SU carburettor manual.
As you say it references to the lower edge of the groove.
