#1 Oil Change and a little smokey
Posted: Sun Jun 10, 2012 5:51 pm
I have just changed the oil and filter on my S1 3.8 FHC.
All very straightforward, however a couple of hangover items:
1. I hadnt noticed before the amount of rubbish coming out of the tail pipes after idling and then blipping the throttle. It quickly clears, but is more grey brown than white and not something that has occured before. I decided I had overfilled the engine (found to of put 1 litre too much in) so drained that out. However problem persists so far - will this clear or could it be more sinister - valve guides, rings etc!! Odd that it has occured after an oil change. Oil pressure is 40lbs at 3k RPM.
2. I have had a small leak from the pipe that runs from the filter housing to the sump (relief valve pipe?). I have tightened up the jubilee on either end of the rubber pipe (is this standard fitment?). It seemed to be weeping from the top jubilee, which seems odd given the nature of gravity. I believe there is a brass fitting that fits into the oil filter housing that this pipe is connected to - could this be the issue and any experienece of tightening/resealing this - its a bit of a pain to get to so only one to get in there when I know what I am doing.
All help advice gratefully recieved.
