I found it very strange that the shock absorbers had to be set different on each side. On the left side I needed to put the distance ring on the lower mounting between the shock absorber and the wishbone, while on the right side it was no room for it and had to be turned outwards. I can not really see any difference so I wonder if it is the angle of the wishbone or the bolt where the SA is fitted that is the difference. Anyone experienced something similar?
I am then left to figure out the anti roll bar. Since I never took the car appart just took over a not to structured bunch of cardboxes I miss some parts. I have not found the plate that is meant to be between the alloy spacer and the bar support bracket. Is it possible that this plate do not exist on my car?
I also have some difficulties to understand exactly how it is fitted. It seems to me that the lower bolt on the anti roll bar fitting is shares with one of the four bolts in the front lower wishone fitting which also holds the front par of the frame and that the alloy spacer goes in there. However it is a plate on that bolt already building it a few millimter out from the frame which I would think should be compensated on the upper bolt in order to keep the alloy spacer firm against the frame but it is not. someone that can help me to see the light? See photo below:
I have Chris' book and it has some very good pictures of the anti roll bar fitting but it appear he do not have the plate I have between the main frame and the front part of the frame. The frame was put together when I got it and these plates were already in place. They probably lift the front part of the frame and I guess also the bonnet but I have no idea if they are needed. Anyone with opinions?
