#1 S2 starter inoperative cant work it out
Posted: Mon Jul 02, 2012 12:49 pm
Hi guys having a problem with my starter would appreciate any suggestions. Have also posted on Jag lovers.
After a 20 mile drive on Saturday stopped for a coffee. Car would not restart just a clonk from starter solenoid. Never any starting problems whatsoever in last 2 years since I acquired car.o
Battery has 12.48v
Starter relay operates when ign turned on, 10.3 v at white/red wire at solenoid.
Big clonk from solenoid and can feel movement believe the pivot is operating.
11.3v also present at the battery input terminal of solenoid when starter switch operated.
When starter engaged only 0.6v at the bottom starter terminal of solenoid.
When direct 12v applied to starter it operates perfectl
So there is voltage at upper solenoid terminal and starter proven to work.
Here is the weird bit. When I bridge the upper (battery) and lower (starter) tminals on the solenoid there is nothing. I would expect a large spark and starter spinning.. But nada.
Have removed cleaned and replaced all connections from the battery to the starter and the two solenoid terminals plus the brass connector between solenoid and battery.
Surely with voltage at the solenoid upper terminal and bridging lower terminal the starter should spin since It will do so with direct 12v feed.
What is going on........
Battery has 12.48v
