I've just got a 1969 OTS, was at the Swiss equivalent of a VOSA test to get it on the road and the clutch totally failed
We've seen there is a crack in the bell housing, further investigation to follow.
However, I wanted to plan a little ahead the jobs I should be doing whilst the engine is out. The list I put together so far was the following:
New coolant hoses
Engine mountings
Rear prop shaft gasket
Clean!
Any other suggestions what I should be checking/replacing whilst it is out - preventative maintenance rather than upgrades
