#1 The disappearing brake fluid
Posted: Sat Jul 07, 2012 3:46 am
In January I purchased a 1970 E Type Jag here in Australia. Unfortunately it has rarely been out of my garage since I bought it.
If anyone can help me with the riddle below it would be very much appreciated.
? I had a leak on one of the rear callipers
? I dropped the rear suspension out and repaired the leak
? Put the rear suspension back in
? Replaced both brake reservoirs
? Bled the rear brakes
? Bled the front brakes, I had a lot of trouble getting the air out of the front drivers side
? Appeared to be braking fine and at no time did a warning light come on
? Left the car in the garage for a couple of days
? Looked under the bonnet and all the brake fluid had gone from the drivers side reservoir
? Brake pedal went to the floor
? Checked for leaks found no brake fluid anywhere
? Checked the brake fluid level warning indicator and it worked fine
? Put fluid in reservoir pumped brakes to check for leaks, none found
? Bled front brakes and moved car out of garage to check for leaks, none found
? Brake pedal now going to the floor
? Checked under the bonnet, and hey presto, the brake fluid from drivers side had disappeared
? No signs of leaks anywhere.
? Passengers side fluid level does not change
I do not have much of an understanding of how this system works even after reading the manual. I have read the recent post regarding the bleeding of the brake system but I am not sure if this has any relevance to my problem.
If anyone has an idea where all this brake fluid is going please let me know.
Ian
Ian
