Dismantling the Calipers
CTDavies
#1 Dismantling the Calipers
Post by CTDavies » Tue Jul 10, 2012 10:48 am
Someone told me if I'd take the two caliper halves apart, I'd never get them together again without them leaking brake fluid. Is that true? On my 2+2 I'd like to replace all rubber seals and the pistons but how do I do that with the two halves still together? Any advise is greatly appreciated - Thanks. Chris
Dennismo
#2 Splitting the Calipers
Post by Dennismo » Tue Jul 10, 2012 2:16 pm
I have done it before. It is just two bolts but I suggest you not do it until you have the two new rubber seals that will need to be replaced when you split it.
I used some locktite when I put them back together.
Dennis
sbs
#3 Re: Dismantling the Calipers
Post by sbs » Wed Jul 11, 2012 3:02 am
CTDavies wrote:Someone told me if I'd take the two caliper halves apart, I'd never get them together again without them leaking breal fluids. Is that true? On my 2+2 I'd like to replace all rubber seals and the pistons but how do I do that with the two halves still together? Any advise is greatly appreciated - Thanks. Chris
Splitting is no big deal. I think the stories originate from a time when the correct o-rings were not available.
