#1 Series one 3.8 power loss?
Posted: Tue Jul 10, 2012 11:00 pm
Hi Folks..another newbee here in search of guidance!
I recently purchased a 64 series one 3.8 roadster and have just returned from the Le Mann classic which was my first real trip in the car.
The car behaved impecably on the way down,though a day into the trip and I noticed the ignition light was staying on.This might be irrelavant to the question I am leading up to,but perhaps some background info will help..either that or bore you to tears!
As I was at the event,I picked up a new regulator suspecting this might be the cure for the non charging issue,though having fitted it sadly not. I then went in search of a dynamo (type c45..not really an anorak).I was very fortunate that the Lister team had a spare c40 on their truck and let me have it..for a reasonable drink ofcourse. I had to space it out a bit but it done the trick and got me home.
Approaching my question..on the way back,I noticed the car would lose power at high revs especially up hill,I could feel the car holding back almost as if I had fuel starvation..spluttering and backfiring on steeper inclines. I found that if I backed off the throttle slightly the power would even out and luckily get me to the top of every hill. As soon as the car was level again or heading downhill the power would come back again.
Finally..my question! Do any of you know what the problem may be? Do you think my problem was related to lower ignition output from the c40 dynamo,or have I got fuel pump or carburation problems from the tripple SU's? I had no other electrics on and amp meter was showing reasonable charge.
Thanks in advance fo any help or advice.
Mike
Mike
