Door lock barrels
Yeldaw
#1 Door lock barrels
Post by Yeldaw » Sat Jul 14, 2012 11:15 am
Help does anyone have a guide on how to replace the door lock barrels on a series 3. I have taken it apart and can't get it back together again
Kes
Post by Kes » Sat Jul 14, 2012 5:04 pm
Im sure you already know this, but don't forget they're not 'handed' ie. one will look upside down. My brother wasted a whole day trying to figure out how to get a lock back together the 'wrong way up' before he discovered this is how they were from new.
No problem is that great that it can't be run away from.
Regency Red 1969 Series 2 roadster.
Iris Blue 1962 MGB roadster
Yeldaw
Post by Yeldaw » Sun Jul 15, 2012 11:34 am
Thanks, I did the same thing I thought they would be handed. But the real issue was that the barrel was sitting about 1mm too high in the lock and would n't turn properly. I tried the other barrel and it worked straight away. I spent al whole day figuring it out. I can now strip them down in about 10 mins. Practice makes perfect I suppose.
fandeland
Post by fandeland » Fri Jul 20, 2012 8:46 pm
Got a set of barrels from Martin Robey. Fitted the LH without any problem but spend one hour trying to fit the RH without luck. Fitted the old one without problems... I now having two set of key to open the car... Are there a RH and LH barrels?
Alban
E-type S2 2+2, 3 Weber’s, O/D gearbox
Range Rover Classic 1987
Yeldaw
Post by Yeldaw » Wed Jul 25, 2012 8:29 pm
Hi I don't believe the barrels are different for the left and right hand. Although I had the same issue as you with mine that the right hand one did n't fit because it was slightly too big to sit in the lock properly so I fitted back the old one without a problem. There is a hole and semi circle indentation on the bottom that needs to line up to make them work.
Not sure if this is much help
