#1 Rear axle chatter vibration
Posted: Sun Jul 15, 2012 11:52 am
by Yeldaw
Hi I just had the pinion seal changed on the diff and now when I turn into a left hand corner and accelerate through the bend I occassionally get a vibration/Chatter from the rear axle. Could it be the garage haven't fitted the pinion seal properly. I think I have read that it could be because a ltd slip addItive should be added is this right.
Thanks Dave
Posted: Sun Jul 15, 2012 11:54 am
by Yeldaw
Sorry I should have said it is a series 3
Posted: Sun Jul 15, 2012 4:43 pm
It sounds like the limited slip clutches chattering, which may well happen if an EP oil without the appropriate LSD additives has been used
Posted: Sat Aug 04, 2012 5:57 am
by Malk
This sounds like an issue I have. Happens after say a run round the M25 then come off at a junction and turn left at the junction roundabout. Feels very clonky and 'catchy' also get what sounds like an eleastic band catching but fear that's the power steering belt!!
I don't get the dif issue when cold. Does happen on reverse most times though and this is after a rebuild.
Posted: Sat Aug 04, 2012 1:02 pm
by Yeldaw
Thanks everyone, I got the garage to put in the additive and it has cured the problem
