#1 Type Approval Information - Tyres, noise etc
Posted: Mon Dec 03, 2012 2:54 pm
A discussion on Jag-Lovers brought up the frequently discussed issue of tyre speed ratings. The latest legislative document is 'The Motor Vehicles (Approval) Regulations 2001' : http://www.legislation.gov.uk/uksi/2001 ... tents/made
It makes interesting reading:
"Schedule 3
Item 16 - Tyres
1. Every tyre (not being a retreaded tyre) fitted to the vehicle shall bear an approval mark in accordance with the requirements of Directive 92/23/EEC or ECE Regulation 30.
2. Every retreaded tyre fitted to the vehicle shall bear a mark in accordance with paragraph 6 of BS AU 144e?1988 or a corresponding standard and the indication given by the mark must not be false in a material particular.
3. Each tyre fitted to the vehicle shall bear marks that were moulded on to or into the tyre at the time that it was manufactured which provide the following service information?
(a)nominal size;
(b)construction type (e.g. radial ply);
(c)load capacity; and
(d)speed capability.
4. Each tyre fitted to the vehicle shall be of a nominal size appropriate to the wheel to which it is fitted.
5. Tyres on the same axle shall be of the same nominal size and of the same construction type. If radial tyres are fitted to the front axle, they shall also be fitted to the rear and if bias-belted tyres are fitted to the front axle, radial or bias-belted tyres shall be fitted to the rear.
6. Each wheel on each axle shall be equipped with a tyre which has a load capacity such that when the axle is loaded to its maximum permitted axle weight, the weight transmitted to the road surface by that tyre does not exceed that load capacity.
7. The speed capability of all tyres fitted shall be not less than the maximum design speed of the vehicle."
Noise and Silencers is interesting as well:
"Item 13 - Noise and Silencers
1. The vehicle shall be fitted with an exhaust system including a silencer such that the exhaust gases shall not escape into the atmosphere without first passing through the silencer.
2. When?
(a)the vehicle is held stationary on a level surface such that there is an unobstructed area not less than 3 metres wide all around the vehicle; and
(b)the engine by which the vehicle is propelled is run at a constant rotational speed of 3/4 S (s = maximum revs),
the noise measured at 0.5 metres from the exhaust outlet at 45 degrees to the axis of the outlet pipe in a horizonatal plane, shall not exceed 101db(A)."
I am not well versed enough with the law to know whether these rules are for Type Approval of new vehicles or are retrospectively applied unless otherwise exempted. The only historical document I can find on line is 'The Motor Vehicles (Construction and Use) Regulations 1978' which makes no mention of tyre speed ratings but does cover noise from silencers. It also lists vehicle makes and models exempt from certain regulations (Lotus, Daimler, TVR, Marcos, Wartburg, Morris, Wolsey etc amongst many). There is a copy here if anyone is interested: https://dl.dropbox.com/u/8496016/uksi_19781017_en.pdf
Here are some extracts from the 1978 Motor Vehicles (Construction and Use) legislation:
Any thoughts from someone with a legal bent? (Christopher?_
"Schedule 3
Item 16 - Tyres
(a)nominal size;
2. When?
