#1 Alternator wiring
Posted: Sun Jan 20, 2013 5:48 pm
Hi Chaps,
Thought i'd tap into your fountain of knowledge.
Refurbing an ex-racer is proving to have it's ups and downs. Firstly, the front brake fluid reservoir wiring had been disconnected (i assume you wouldn't want warning lights flashing on when your're running around the track unless oil or temps)
Anyhow, i replaced all the reservoirs and reconnected the front reservoir wiring - hey presto all good and working :-)
I couldn't "find" the wiring for the rear reservoir brake fluid warning initially - however after un-taping the loom on the N/S frame it appears that it had been disconnected and the earth part of this loom been connected to part of the alternator wiring :-( with the positive wire for the brake fluid reservoir just wrapped into the loom
Obviously, i am keen to re-instate this rear reservoir warning lamp and if i unplug these two wires and connect to the reservoir - the brake fluid warning lamp works correctly.
So, i now have a situation whereby there are four wires off the alternator:
Main thick battery + - connected and ok
Earth - connected to the alternator body - connected ok
F+ - this was connected to the brake reservoir loom - earth
A N other wire - goes into the main loom
I suppose my question would be - where should the F+ and A N Other wire route to?
