#1 Panels, welding and things
Posted: Mon Jan 21, 2013 6:50 pm
Hi everyone,
Well the E is inside the house on its rotisserie and being able to spin it round is just brilliant...
So bit more rust than I thought, but not as much as I feared. Extra week of welding to do manly because the various botched repairs and brand new floors were attached by some means that someone thought was welding, but looks more like random bits of chewing gum and are about as good structurally as chewing gum!
But couple of questions - I spent most of my time welding my boat and still have the weld three times philosophy (root and big cap each side) makes it water tight. Obviously not a good method for the E! So when joining new panels, I will try to spot weld and forgo the temptation to weld complete runs. But when you old hands do repair plates, do you spot or weld completely around as per the mot instructions?
With the rear inner wheel arches, I was going to buy new panels, but they seem very expensive for what is almost all flat plate. Some of mine are saveable too, but I am very tempted to weld a complete plate over the weird little shelf at the rear of the wheel arch. The shelf only seems to have two functions - to trap water and then once rusted out, be a pain to the poor soul who has to re weld it. Is it tantamount to making the queen ride the bus, if I were to weld my new plate over the shelf to create a smooth surface?
Finally what colour were the wheel arches from new? Did they match body colour who were they painted black?
Thanks all
P.s. whoever said only two people are required to lift a body tub around must be built like Geoff Capes but with out the budgie... Took four of us and still dented the rear wheel arch.
Thanks all
