I kept one of the original seals when I dismantled the calipers, probably because it was the only one that didn't end up torn to shreds. Here you can see how the two compare
The original seal fits beautifully between the caliper and the piston.
Here you can see how the seal fits in the groove along the top edge of the piston
Here you can see how the new seal fits. Getting it in the groove is much more difficult as it's much tighter. You can also see how it is now warped. There is no way in hell I'm going to get this to fit on the shell properly.
Here you can see the difference in the thickness of both; the new one being much thinner allowing for less travel needed when the brake pads get worn
so my questions are
-does someone make dust deals that are 100% like the original?
-should I just cut away some of the material, enlarging the hole and therefore achieving a better fit?
-shall I put the new seals on the pistons for a few days, hoping they will take on a new shape more like the original ones?
Any advice is, as always, greatly appreciated.
--Chris
