#1 E type Sump rear sealing differences ?
Posted: Mon Mar 18, 2013 3:09 pm
Just to pick people's brains and hopefully confirm my thoughts.
As it was a wet and windy weekend, I was working on my 4.2 spare engine and going through some parts. I have a spare E type finned alloy sump, but looking at the sump's rear sealing surface where it mounts up to the crankshaft rear seal cover assembly containing the rope seal, the sump has no recessed sealing area to take a rubber seal, just a smooth semi circular surface.
Am I correct this is an early 3.8 E type sump which would use a different crankshaft seal cover assembly to the 4.2 one, (C19687) ? so that the 3.8 cover assembly would incorporate a groove to locate a seal, (rubber or cork ?). Any idea of part number ? I presume there would be other XK engines that would need a such grooved cover assembly - such a cars with tin sumps ?
If I am correct with the above, would the 3.8 cover assembly be compatable to fit the 4.2 crank, albeit going through the nausea of fitting the rope seal correctly, or would it be easier to modify the alloy sump sealing area to incorporate a suitable seal ? Or just offload the 3.8 ? sump ?
regards,
S1 FHC 4.2
regards,
S1 FHC 4.2
