as part of the process of restoring my 63 FHC it is being converted from LHD to RHD
I bought a used rack off ebay, described as for series 1 or 2
from the date stamp, i am assuming it must be a very late 4.2 as '71 is evident
I have noticed that this RHD rack has a different set of internals as well as some different details (much prefer the elegant profiling of the rack of my LHD original, on the right in this photo)
you can also see the difference in the profile of the spigot, the original LHD is on the right which has a slightly larger diameter spindle and different length teeth, and has 8 teeth, wheras the new RHD spindle has 7 teeth....
was this an option on the later 4.2's or standard fitment....making for a more relaxed driving..?
and by the time the later 4.2 rack was being built this lovely little identity pressing was replaced by a plain one
and here they are together, otherwise identical...(original LHD on the left this time)
so my question is whether a 7 or 8 tooth on the spindle makes much difference...I seem to have little choice if I use this new rack, unless I replace the bearing in the aluminium casing
can anyone tell me what the difference in feel might be ?
thanks in advance
regards
Jonathan
